JCB 537-135 wont tally in (SOLVED)
jasonplantuk1
hi guys. i have a JCB 537-135 telehandler, Year: 2000. It wont tally in, tallying out perfectly, 2 sections obviously, i removed the ram of the big section and it slid in on its own, so the ram/rams are at fault. anyone seen this before or have any idea what it could be? machine is putting up the pressure as i took the 2 valves out of the cylinder block at the bottom of the top ram and oil everywhere. Ram seals away? Valve issue? hydaulic pump itself? otherwise shes doing absolutely everything else perfect. any help much appreciated! Thanks, Jason (07756520878)
Check all your where pads. By your right shoulder, on top of the ram is a block with valves, when cold and on the ground, remove both valves check the o rings, normally the middle ring on the larger valve will be split, send photos👍🏻
