K
Ktriky
I’m having trouble with my 2004 JCB 214. Unit runs great. Forward and reverse run fine for 10-15 min. Then it stops moving forward or reverse. I'm losing pressure when it stops moving. Cold pressure is fine but it drops when hot. I've already changed out the pump. Then the pressure release valve. What else could it be? Transmission Fluid level is fine. No funny noises. When I let it sit for a bit it will run fine again.
I'm lost and dumping money into this thing.
