I have a Jag XK8 2001 . When I took it home a couple years ago the drivers seat won’t go back or forward. It has a module under the seat and this is clicking when I work the switch either way . I’ve checked the plug with 2 wires going to the motor .
When I push the switch one way one of the wires is live . When I push the switch the other way the other wire isn’t live .
The little black box beside the motor has 2 wires in it . Does it look like they should both be going live when the switch is pushed either forward or back . ?
What is the little black box for ?
Should I try a live feed down both these wires to see if the motor moves ? Do you think one wire should be an earth , but if that’s the case how does it change direction ?
