Pedrod355
Does anyone know where i can get a bolt on manifold? Don’t want to weld it on!
make one? ... 'spect Aiden @CPS 'll be able to supply youWhere’s best to get manifold? So am presuming you don’t get a bolt down?
No, you'll have to fab it somehow. cast dipper?Where’s best to get manifold? So am presuming you don’t get a bolt down?
I have some on the self, they are bolt on versions although I normally weld them as I don't like drilling booms/dippers etcmake one? ... 'spect Aiden @CPS 'll be able to supply you
they do, but couldn't find one a few weeks back when this was being discussedFlowfit probably do one they have a massive range
Can't see them taking the pressure being aluminium.Is this what i need for plumbing in hydraulic tilt hitch ?
Thanks for clarifying that was what was confusing me that they looked open right through.You won't be able to weld on the aluminium blocks. I see they come with bolt holes though.
Also the are typically manifolds so all open but what you possibly want is two separate circuits in one block
