Ifor led lights
I don't think the junction boxes used, with just the push in lucar type connections help.
And the lids that fall off and disappear for fun, but can’t be replaced other than buying a complete new junction box….
My tipper is the same . The wiring is shocking . Mine has a charging module for the battery and before it was 2 years old I renewed it myself with a module that actually managed to keep water out . I had to wire a new 13 pin socket on it 2 days ago and some of the wires were black 😡. I will be rewriting the whole thing as soon as I have a shed to put it in .
I had a brake that I fixed - crap design where the fog and reverse light has a loose wire that dangles between ramp and bed and redone it and the wires are black
Looking like it was a failed connector to the rear light. Something inside the sealed plug was shorting, only marginally not enough to set the multi meters buzzer off but enough to display
