Yep, watched a few, most of which are from guys doing the welding are from across the pond.
So to weld the 10mm thumb mounting plate to the dipper, I was going to cut a groove in the mounting plate straight down the centre so it straddles the long dipper weld that the E10 has, do i bevel the edges of the mounting plate to accept the weld or leave as is.
The rods, 6013 or 7018, these do vary in price greatly depending on brand it seems, any recommendations?
I know the weld will have to be multiple passes, do I start with 6013 then move onto the 7018, if I’m using a 130amp max machine, do I drop the rod size down, say from 3.2mm to 2.5mm to get the penetration.
