Hydraulic submersible pump
Customer has a boat which helps
Next picture will be of an E10 roll-bar just visible sticking up out of the mud.....
That's why the E10 is going in first- the E27 can pull it out!
Under the silt which I will push out the way first, it's remarkably firm. We shall see, I'm used to working in situations like this anyhow. I remember once I had my old Shaeff in a bog on four sleepers digging a V-ditch to drain. It was a lovely hot day and I was in shorts and sandals. I got off for a piss, onto a sleeper, and that particular sleeped sunk down enough for me to feel warm water all the way up to my calves!
I'm loving this pump- being submersible and very quick to prime, it's a joy to unblock and use as the levels drop. SO much easier than faffing around with a petrol pump. Got to say, a hydraulic 4" trash pump would be lovely, but I'd turn the stream black and have the environment agency breathing down my neck in five minutes flat. :whistle:
Looing good now.
Russell
Did you use any special fittings or just run it straight off the E10?
Looing good now.
First rule of getting in a pond, make sure you’ve got a bigger machine on the bank waiting! 😬, or at the least have access to one in a hurry.
this is the 4", chops up the debris no bother so no having to de-clog. Poor fish!
Fearsome amount of water it shifts at full chat.
Straight off the E10 as the aux flow is around 20l/min. Mine has the extra oil coiler on it but it shouldn't matter if it didn't running a pump underwater- best heatsink there is!
