Hitachi zx180 top rollers
Left hooker
Left hooker
Anyway got 4 top rollers 16 bolts and delivered next day for £445 including vat so happy with that👍
just need to get the remaining one😳 off and extract the bolts now😩😩
Who from can't leave us hanging like that mog
Managed to swop two out of the three top rollers easy just jacked up the track and undid simples👍 was-bloody tight🙄 But the other one had pulled the thread out of one hole and sheared the other three bolts off😢
tried the obvious weld a washer on then a nut but were too tight and just screwed the nuts off🤔 so drilled one to try an easy out 😢😢 no use way too tight
So on to plane C
cut the carrier off so I could get it in the drill press managed to drill out and re-tap
then glued it back onto the X frame👍
all bolted up ready for action😉
So on to plane C
View attachment 29821then glued it back onto the X frame👍
rough looking old pedestal that Mog ..... 'spose they've taken some 'hammer' in their lifetime's :unsure:.... deffo the easiest solution to that problem (y)... were they forgings, you think?? looks to have had a 299 weld holding it on originally or'd you polish the weld up for the photoshoot :giggle:
