Help cat 301.5 repair manual
P
Paul
Hi guys has anyone got a service or repair manual for a cat 301.5. Or at least know where I can download one without adding credit card details. been done before
I do but alas itd be a 2 day job to get it out.
What are you wanting to know?
P
Paul
Cheers for reply. Just bought one and going to give it a good service and check it over. Nothing essential yet but alway useful. Is yours electronic Copy?
No its a cd from cat from when i bought mine new from finning.
They are easy to service. Keep an eye on the rads blocking, they look fine from outside but clog up in between them.
P
Paul
Cheers do you mean fins clogg externally or should I flush cooling system through?
You won’t need the manual just to service them mate. Get the filters and oil and crack on. Don’t forget the final drives.
Guessing it’s a pair of rads, one for oil and one for water and they get clogged in between. Just unbolt the front one and pull it forward a bit so you can blow both through individually
P
Paul
Not worried about the service just something I like to have for the future. First Digger for me just for some work on property.
Its the gap between the 2 rads that can bung up. Once you get the side panel off you will be able to see what i mean.
The 301.5 is a very arse heavy machine so just bare it in mind when on slopes.
P
Paul
Cheers will take it slow and easy till I get the hang of it. Will look it over Saturday so thanks for the advice.
They are a good little machine with plenty of power.
If you didnt know the round button on the floor if for 2 speed tracking. Sometimes they bung up with mud.
P
Paul
Cheers didn’t know that only got it delivered yesterday so haven't played with it yet.
I wouldnt know without looking, ring finnings they will give you the best answer.
What year is your 301.5?
