P
Paul
Hi guys has anyone got a service or repair manual for a cat 301.5. Or at least know where I can download one without adding credit card details. been done before
I do but alas itd be a 2 day job to get it out.Hi guys has anyone got a service or repair manual for a cat 301.5. Or at least know where I can download one without adding credit card details. been done before
No its a cd from cat from when i bought mine new from finning.Cheers for reply. Just bought one and going to give it a good service and check it over. Nothing essential yet but alway useful. Is yours electronic Copy?
Guessing it’s a pair of rads, one for oil and one for water and they get clogged in between. Just unbolt the front one and pull it forward a bit so you can blow both through individuallyCheers do you mean fins clogg externally or should I flush cooling system through?
Its the gap between the 2 rads that can bung up. Once you get the side panel off you will be able to see what i mean.Cheers do you mean fins clogg externally or should I flush cooling system through?
The 301.5 is a very arse heavy machine so just bare it in mind when on slopes.Not worried about the service just something I like to have for the future. First Digger for me just for some work on property.
They are a good little machine with plenty of power.Cheers will take it slow and easy till I get the hang of it. Will look it over Saturday so thanks for the advice.
EP80/90 at a guess .... anyone ???What oil does the final drive take?
Yeah 80W90 would be spot onEP80/90 at a guess .... anyone ???
