Hanix h26b headlight relay
Mike_510
Hi
Anyone had to rewire a relay plug. The relay has gone but I can’t find one with the same pin out anywhere online, all the relays have a different pin configuration. I was might be easier to an adapter then I can use a normal 5 pin relay, unless someone knows a place to buy these Japanese relays.
Mike_510
I can confirm the Bobby pin, removes the old connectors from the old relay housing, and you insert them pins directly into the new housing, then use common 5 pin relay. Bit of messing about, easier than cutting and adding new connectors. New relay and housing £4 on Amazon.
