O
Old Operator
I am restoring this, the slew system had failed, & an old Twose backhoe slew system was added by past owner. This moved the Kingpost 21'' forward & added much weight putting it off balance, so could hardly keep rear wheels on the ground. I have built a new slew post & built up the fixed slew table with bead pad welding. I got measurements of the post from another owner & also built 2d mock ups to prove the geometry - the boom ram when closed must not pass below the horizontal, & boom rear must be vertical when this ram fully open. Also the 'modification' had meant that only 7/13th of the ram was used to move boom through its arc. The new post is welded with E7018 root run whilst hot, then built up to leg length with E6013. I had the original slew rams & chain as spares. Seen here is the New post fitted on top of the new thrust washer. I still have to get & fit the plate wheel sprocket underneath so we will have power slew. The boom geometry has been tested under power, lift ram is 3 deg. above horizontal when closed, & boom rear stops in the vertical when ram fully open. This means the rear of boom will not touch the spool chest. Next job is to mock up this valve support & the removable seat support before welding all if sound.
To get this far was only possible because I got the back gear going on my Victorian / Edwardian large lathe. It bored a 3'' dia. hole in 2 off 20mm thick plates, did same in nylon table washer, & bored the 'bucket pin tube' holes with a cutter off ebay.
I am going with a boss & cross pin underneath - rather than the original design with two small keyways @ 90 deg apart, - this often failed on these machines. Granted this is a 'wheelbarrow machine' but do you restore old British engineering or put your faith in something 'Carter'. There is a small type Gopher on sale in Leeds (50mm rams) for £2300 good order, Powerfabs often sell on Ebay for more than they cost new! The Powerfab is still made under the name Otas in Eastern Europe. These machines are quite prized in France where towing laws are different. Info on the Lathe repair & Pic here if anyone interested
Braze steel gear onto hollow grey cast iron shaft
Hi I need to braze a replacement steel pinion onto a hollow cast iron shaft. The pinion is now ground/machined off & the new one a smooth push fit on. I am not sure if the shaft & pinion were once one casting or that the latter was heated & interference fitted (shrunk) on, as there have been...
www.mig-welding.co.uk
