Or you could use a bit of wire that looked the same thickness
Just don’t hold it!
DC current will weld the contacts together of undersized switchgear.You sound like you know your onions.
I was I told switch gear/ isolators on DC circuits (pv) needs to be rated at twice the amp rating.
Why's that?
As above, but it's because (at 50Hz), the current has a zero volt crossing 100 times a second. This extinguishes the arc as the contacts start to open.I was I told switch gear/ isolators on DC circuits (pv) needs to be rated at twice the amp rating.
Why's that?
