Finally going for it,lorry purchase.
to quote everyone when I was transitioning from 10 years of X to ISO on the 'Drema .. you'll soon learn :rolleyes::ROFLMAO:
Not quite as easy with cranes as there is no discernable difference in the way everything feels as you stand there. So absolutely nothing to jog the memory as to what you are doing. Atleast with 3cx Vs servo you go from Infront of you to the sides.
Ones the total opposite of the other.
X to iso is easy to swap. I learned on sae pattern and I used to swap the 432 round from iso to sae and back every so often to keep me sharp with it.
Lots of people like the epsilon set up but also lots of people convert them or order them new with atlas pattern.
I never managed to get use to the epsilon setup after learning on a hiab and palfinger. The palfinger was the best as the controls swiveled 180 degrees so you could work over the front.
after a solid 10 years on Jake's X and zero ISO in that time, took a while to come back ... was ok on either after a few weeks (bear in mind I didn't use them daily) ... would have to think about X again now :LOL:
