T
Taat
The machine is Takeuchi TB 1140, 2006, with over 12000 hours on it.
This came out of the blue. No signs of any similar problems before that. I started the machine normally, then drove 10 minutes to my neighbor. As I arrived I had to disengage the key two times for it to turn off. After that it was hard to start. After we managed, the rpm were very low almost wanting to turn off but not quite. No throttle control was possible, but can hear and feel the throttle motor working when trying to raise rpm on controls. Can’t turn off the machine without emergency shut off cable connected to the injection pump. Can raise the rpm but have to manually assist on the injection by forcing the lever where the cable from the throttle motor is connected. When manually raising the rpm to the max, I they are able to drop to medium when pressing the medium button but not to the low rpm, even though the light is flashing on low rpm but it stays at around medium. After that it started normally but couldn’t turn off with the key and the rpm wouldn’t drop to the low. The next day there was again hard starting and had to manually raise the rpm but I only did to the about minimum, after removing the key the machine would turn off but would also if I would switch the rpm to the low.
It almost feels like the cable from the throttle motor to the injection pump is getting stuck? Or is there some electrical problems causing the throttle motor and cable to not be set at correct position? Is the injection pump the problem with the throttle lever being stuck and the cable is unable to pull it efficiently? I would really like some opinions on this.
