Dumpers - Cab or no Cab
guy that i worked for always insisted that the digger and dumper should be the same size ie 3 ton digger 3 ton dumper 30 ton digger 30 ton dumper
always seemed to work out fine
Digger should always be a dumper and a half bigger...... 1.5t digger, 1t dumper, 2t dumper 3t digger, 6t dumper 9t digger, 9t dumper 14t digger, 25t ADT 40ish ton digger.
That's my view anyways
Canal Navvy
Canal Navvy
I have it in the back of my mind that for maximum efficiency an excavator should fill the dumper in seven passes 🤔
Ideally 4 passes for anything over 20 tons.... Under 20t you are really talking a need of a cycle time rather than passes.
Efficiency wise regardless of size your cycle time should be under 2 minutes in poor conditions.... When working for Trax I could setup a 40t EC360C on a bench and load A25c's in under a minute and A30's in just over a minute.
That said a poor driver can completely blow the sizing out the water with just a poorly run load out. As I did a few times when learning @Conor 🤣
I really like my 1.5t swivel Thwaites - its been a great little dumper - basically a big wheelbarrow, and there's not many places it wont go. Sure its half the size of a 3t dumper, but these are easily and cheaply hired. So if I really need to move stuff, I hire a 6t and do it properly!
But for most of my groundwork jobs, the 1.5 is ideal.
