so next thing on the agenda was working out roughly how much ram travel I was going to need to get it to tilt through 120 degrees .... and what sort of bracketry I was gonna have to dream up ....
so - full right
and left ...
gave me a relative idea of how much .. IIRC it worked out at about 620 mil stroke to take it from 60-0-60 deg.s
cylinders weren't a problem - searched every where for trunnion mounted though and failed to find any, or even loose trunnions I could use. ..... so had to come up with a mount system that i ended up with
now ten years ago trying to find or get any real info on the black art of tilty control was like trying to get a night out with Demi Moore/Angelina Jolie/whoever ... it just wasn't out there and took me a long time and a lot of questions to finally suss how to achieve it and then a bit longer to determine how I specifically was gonna manage to make it work ... then it was shopping time
couple of 700 mil stroke rams and a Cetop3 manifold with three solenoid op. valves
which only two of arrived and not as spec.ed so went back
to eventually be replaced with what was ordered originally
plus I also needed to be able to control these ... and my stick tops were devoid of buttons, bar the two on the right stick .... so this arrived from a German hyd.s supplier
only needed 4 buttons and the six button unit was like two euros dearer, so thought - never know - might come in handy to have a few extras
then had to make a custom adaptor to get it to attach to the Rexroth stick at the right
angle of dangle to suit
and persuade it all into place
and swap the buttons around to give me side to side colour coding rather than up down (never bothered to look at 'em after, after a few days of use - LOL) ... came out easy - little sods to get back in though.
aaaaaaand then had to create a loom to link all this lot, including the existing two right stick buttons, from the cab to the dipper end ...
and then find a suitable termination / socket to suit multiple ways (there was more to come here)
which I was lucky to have sat ... these ain't cheap
and i know you're all getting bored with the nitty gritty bits and want to see all the rest of the lumpy bits, but all this tish has to get sorted too
and took a hell of a lot of time to dream up and install
