Stubota86
We wouldn’t normally bother but would dampen the base if it’s really dry and spray it with water a few times a day depending on weather once the top has cured for a week or so
How much!!!!Volumetrics are a good bit of kit, but the cement dust that comes off them is nasty, they also nearly always leave a mess on the floor, either a pile of slurry or sand, which is not ideal on clean jobs.
I get drum mix from Hanson for £57/cube cheaper than the guys with volumetric - on small loads, they get cheaper on full 9cube but still always work out dearer!
But they can’t run at those weights anymore apparently.get a good 10 cube from a volumetric. Heavy wagons when fully loaded.
How much!!!!what strength is that?
35N is around £95 a Cube. I'm making my own for £66 in materials.
You're lucky then, they won’t do it round here anymore, but I’ve not tried all the suppliers I suppose. A change in the law means they shouldn’t be exploiting the loophole that allowed the higher weights. But maybe things have changed again?they were saturday
£80 a cube round these parts, ready mix touch cheaper burt more hassle. Only need to be a cuber over and the saving is gone and you have mess to clear up.
As far as I know, they were running the trucks to their technical design maximum gross, which in the case of the Scania 8 wheelers that my guy uses, is 38t. And they were run as mobile plant I think, did not technically need MOT, 6 week checks ect, although the guy I use does. From what I’ve been told they can no longer run like this, and need to adhere to the 32t max gross of an ordinary 8 wheeler, hence them dropping down to 7 ish cube from a good 10.What loophole allowed higher weights I thought overweight was a black and white thing?
We've got a good firm here wrightmix his trucks have always been really modern and well equipped. I usually use them for footings.
The pricing used to be a lot more clear. A set cube price under 4m3 and a cheaper one above that. Dare I say you used to get better rate for big big jobs.
Now when you ring up thought they can't give you a straight price per cube on single lorry loads. They want to quote you on am exact amount then if your over or under the price changes but not by a set amount per m3. I think it's how they've worked their haulage costs into the rate.
As he saidAs far as I know, they were running the trucks to their technical design maximum gross, which in the case of the Scania 8 wheelers that my guy uses, is 38t. And they were run as mobile plant I think, did not technically need MOT, 6 week checks ect, although the guy I use does. From what I’ve bee; told they can no longer run like this, and need to adhere to the 32t max gross of an ordinary 8 wheeler, hence them dropping down to 7 ish cube from a good 10.
Thats my take on it anyway, I’m no expert, just what I’ve been told.
Those volumetric trucks are not cheap, really not cheap! And cost quite a bit to maintain and keep working from what I’ve seen.Bloody hell why wasnt the concrete cheaper
