Picked this up from JB Equipment, about 2k plus vat. Seems good. Mounted my hitch plate from my little grab to test it, will get a proper plate made up soon.
I tried it around the yard. It knocked a two foot high pile of loose type 1 into 1 foot high pretty rock hard- will have to put the ripper through it before I try to load it with the forklift bucket
A single brick under it was reduced to good fill pretty easily, so I'd say it will put rough crush down fairly well. It weighs 200kg. Was this or a big forward/reverse and this sit in well with my 'less labour' ethos. It should work (but not as well) on my 2 ton also.
Funny how you buy things and then straight away you find a use for them. Got a small pond to infill to then lay a patio over. Should be perfect. Also got a twenty metre stretch of sandstone driveway up a fairly steep hill to rip and re-level. Then hopeully some local bridleways up on the hill. Will also be ideal for small driveways.
Don't worry @Regy53 , I'm still toying with the idea of replacing my cheapo petrol wacker with a big Lumag single direction machine
