Fts1
Hi
We believe it was fitted correctly as we can see this from the cctv.I presume your employee just dropped the hitch onto the truck but failed to actually open it and lock it on?
Ultimately you are responsible for your load. I guess dangerous driving is a catch-all.
How did it fail then?We believe it was fitted correctly as we can see this from the cctv.
So how did it come off? What failed?We believe it was fitted correctly as we can see this from the cctv.
We don’t know how it’s come off.So how did it come off? What failed?
Was it a very worn hitch? I’m going to guess it’s a fairly old trailer if it’s got a Bradley hitch? Nothing wrong with old kit essentially, but was the hitch worn out?
Not going to be very helpful but pickups are exempt from tow ball heights.
If your employee hooks it up it's still on you, the driver to check it is correct.
Part of the trailer test is to ensure the trailer is properly hitched to the trailer by winding the jockey wheel down to ensure they are hitched correctly.
Your going to need to get an expert witness just make sure they are an actual expert and some "engineer" with zero relation to the field
Thank you for this.Only time I've heard of it was a 16ft flat that came off a transit on M1 carrying unistrut...didn't hit a thing ended up on top of central reservation... incredibly didn't hit anyone ...
They had it proven that the ball had worn enough for it to pop off..but dint think they got prosecuted.
I'd deffo be getting a very experienced lawyer.. obviously...and expert engineers etc .
Towball height is irrelevant in my opinion. And if it’s high then it can only aid the thing staying on as far as I can see!We don’t know how it’s come off.
A specialist has viewed the trailer and vehicle.
The trailer is 20+ years old, the hitch is an old style Bradley double lock.
How do we check for wear? The handle lifts 10mm with the safety catch on?
The vehicles tow ball is 528mm from the ground which is apparently 110mm above the recommendation, would this cause an issue?
Don’t think so. I think you’ve got to measure the actual jaw that sits against the ball, not an easy thing to do properlyIs this how to measure a certain amount of wear?
I was just going to put about the safety catch to measure wear, if I remember correctly the should be a gap at the bottom of the catch when attached.Is this how to measure a certain amount of wear?
However it came detached. Shouldn't the breakaway cable lock the brakes on? I've often wondered why a suitably rated chain isn't a requirement in the event of a breakaway too but perhaps there a reason for thatWe can suggest everything under the sun...but in this case do your homework and find the very best lawyers and experts you can whoose advice and opinions will carry weight in court. I don't say it lightly and I can't stress enough get the right guys on the case your going to need it...
Genuinely feel for you and it's a wake call to any of us that tow to double check![]()
