Cylinder for post knocker
$330usd for everything.(excluding valve, took that to confirm thread) There is one more female QC not in the box. Buy once cry once🥲 it rhymes so it must be true.
Trying to decide if I want to replace the 90deg fitting in this pic with a 90def that has a leg run off to the right. Then I could add a second on/off valve mounted beside this one.
Or do I go ahead and plan for the future and run second and third auxillary lines all the way out there? QC bucket coupler is coming next😎
drill the side of the fitting and weld a socket onto it - carefully
K
Keif
I'm finishing up a big fencing job through the woods. The driver(and operator lol) are pretty amazing drove in 127 posts, all in the woods. Sometime the post would hit a big root but it always broke through them.
Its plumberer and levelerer than the pictures make it appear🤷
Left hooker
Left hooker
Get past with your mini digger to run wire from your holder you made 🤔
K
Keif
Starting point looking down to the first bend, which is the picture in my last post.
Looking back to the start, going around the corner.
This was a long run that went around two of these corners, with a new roll spliced in the middle. With the blade as a front anchor you can use the joysticks to adjust and tension fence. Gets it twanging tight.
Nice one, right machine for the job there. What other machine can clear the ground, knock the posts in and pull up the wire on a tight job like that. Always thought diggers made the best all round fencing machine.
