JerryRtilt
And maybe the brickies won't moan about not enough room to workAt least the 750mm digging bucket I've got will finally get some use.
Plus the extra 150mm width means there's extra muck away too![]()
Well when you think it's only 50mm wider for brickwork but they want footing dug 150mm wider...doesn't make sense to me.And maybe the brickies won't moan about not enough room to workno.
I think in this case it's increased because of the extra loading of two floors of block and beam.Well when you think it's only 50mm wider for brickwork but they want footing dug 150mm wider...doesn't make sense to me.
What about climate change?Well when you think it's only 50mm wider for brickwork but they want footing dug 150mm wider...doesn't make sense to me.
Push them more!! They where taking the pi55 with the first quote!!I can now have it for £3800.00 less if I decide to have it within the next 5 days...![]()
Id sooner have something else now they have tried it onPush them more!! They where taking the pi55 with the first quote!!
I’d keep going back to them just to waste their time after trying to take the piss, don’t think I’d spend my money with them though!Id sooner have something else now they have tried it on
Name and shame.I can now have it for £3800.00 less if I decide to have it within the next 5 days...![]()
DefinitelyPush them more!! They where taking the pi55 with the first quote!!
I've had the same experice from takeuchi and bobcat. Both quoting 36-38k. Sod haggling, il take my money elsewhere.Name and shame.
Versatile Equipment tried the same with me with an E27. Wanted nigh on £37k, dropped it to £33k as a 'special deal for a long term Bobcat customer'. Fk right off.
That's with a pretty good spec from memory, aren't they all twin proportional roller aux?Of no interest to you better contractors im sure but I think a liugong is about £24![]()
Yeah, they’ve got everything on as standard, and even on my 1.5 you can alter the flow of both aux circuits with simple knobs on the dashThat's with a pretty good spec from memory, aren't they all twin proportional roller aux?
All cavity walls are 750mm here, internal walls are 600mm, building control want 150mm either side of the wall. Some jobs now are 900mm founds for cavity walls
750 footings are nice to dig, i think the days of 450 founds are pretty much gone, unless it’s a single internal ground floor block wall somewhere!
None that I have dug recently that are under new regs have gone wider than 600mm.Still doing 450 for one developer to save money. Plenty of machine drivers that really struggle with such a tolerance
