N
neil1977
The access to the block is very restricted so I think I’ll have to drop the axle to enable access to even attempt a repair on it. I’ve a local mechanic assisting me on this job.
Druid, I agree. I’ve no idea how this has happened, it’s not in a place to have received any trauma as it’s so well concealed! You’re right it’s not a tapered connection so no extra pressure. I had a helluva job of loosening the union, it seemed ridiculously tight. It’s strange, I can’t go pointing fingers but a Jcb engineer was at the digger last week as I had an issue with the immobiliser and also there was a couple leaks in which they replaced the hoses. Reason I’m saying this is because a couple years ago, the same engineer came out to a fuel pump problem which it turned out to be a crack in the casing of the pump! When I left the machine everything was turned off but next day the radio was on and my battery was flat. He’s an extremely unpleasant young man and he was the same last week! I’m starting to wonder if it’s sabotage or I’ve got a dodgy machine! Too many major issues with it as it’s only done just over 3000 hoursby ''bottom side'' I presume you mean where I arrowed ? could well be vee-ed and TIG-ed, as I said .... good TIG man with a nice fine touch'd make a good job of that ...... it's all the sundry hassle that'd go with getting it done is the major grief... TBH I really can't see why it's split ..... if it were a tapered adaptor in there I'd understand it, but it's a parallel union with a dowty on a mate face, so it's really odd, unless it's had a trauma , but can't see how????
.... over-dogging that adapter'd strip the threads, not burst the port
