Would a new set of bosses in the bucket lugs be an option for you? Burn the old ones out and weld some new ones in? New set of pins can be had from Vicary Plant for fairly reasonable money. Would tighten it up like new, especially with a new dipper end bush.Not sure what to do about this problem now. It is the bucket that I use most nowadays and in fact I think it is the third 3CX that I've used it on which might explain why I have the problem. If I was still contracting then it would probably be time for a new bucket but I will try and think of a cheaper solution.
