With things that are only supposed to flow one way, such as breakers or one way motors, is it a good idea to install a check valve in the return pipe? Would this prevent any flow or pressure getting past it if the return pipe was pressurised by mistake?
Further to this, hypothetically speaking, in that it woudl make a SAVAGE power pack for a 24t log splitter
, could one plumb two 30/l min powerpacks into a one big bore pipe via check valves with no ill effects if only one pump was running?
