cat scaner calibration?
Russell
Where do you get your cat and genny calibrated?
Is it worth doing?
Is it worth doing?
Calserv did my last one.
If you have a Leica ezicat make sure the place that does the servicing is actually able to do them as not everywhere has the kit
Sunbelt rentals offer cat and gennie calibration
weren't they A plant?? wouldn't have trusted our local depot to tune a radio :oops::cry:
They are an American company that has been on a buying spree in the UK.
A plant is among the companies they have bought as well as some surveying equipment companies. I think our local one is Opti-cal. And I think some traffic management firms.
So you may drop it at an ex a-plant depot but I think it would go to a survey firm to sort.
T whiting
T whiting
Where in the country are you based as that'll make a bit of difference as to where you'll want to use.
I've never had mine done but I wouldn't stand by it on a site either I have it because there's never one on a domestic job
Left hooker
Left hooker
Bought leada acrow the shuttering and forms company last year as well
tinydigger
tinydigger
where abouts in the country are you? my mob (Gap Group) have a few survey depots dotted about the place and i know they can do cat and genie calibrations sometimes same day if you lucky
Russell
I'm on the Isle of Wight so expect I will have to post it somewhere.
F
fred
i do my own, the software is free and you can buy calibration credits.
Cheers, is it all software based or needs additional hardware?
F
fred
open the battery compartment on the scanner and there is a usb connection similar to a samsung phone. plug that into the pc and job done.
How do you go about calibrating one then Fred? Mine was last done in 2001 so pretty sure its older than USB itself. But the principle should be the same?
I think if yours is that old it's probably better you get a newer one. Early 2000's i think something changed and most cat scanners became obsolete and all manufacturers brought new ones out (something to do with radio frequency they used and interference i think).
T whiting
T whiting
Keep it Ollie I have a cat 1 in the can that I often have to get out the van when the cat 4+ super special depth sensing one won't pick fa up
