Case hardened pins
I got them in so I’m going to get them out !!!
Angus done it originally ! He’s to busy to do it again now but I have a good fabricator that works with him on the case so I will let you know the plan when we go at it ! It won’t be easy though . 🤔
I wouldn't put a case hardened pin in unless it isn't hardened at the ends were the weld is going as it will just crack the weld off over time!
Id go with a good pin maybe en8 and make sure the hitch is clamping it right from the start!
Surely there should be little to no wear on the pins if a hydraulic hitch is closing properly?
Have you ever filled a tilt rotator pick up jaw and then line bored it ?
Is this not the done thing? I’ve heard someone does it locally to me but can’t find out who . I know Aiden’s done some very tidy line boring in the past
