Case 580K Front axle
jddevel
Need advice on a Case 580K 4 wd wheel digger. Leaking oil badly from behind the front right hand wheel. So some questions. Firstly any obvious suggestions as to what seal may have gone ( it did appear quite quickly however). Also any obvious problems/advice getting at the end of the axle. Finally what oil should the axle contain please?
I have a login onto the new Holland parts system (you can easily set one up yourself). I’m pretty sure they are the same axles as the case, can anyone confirm?
I will try to login later and get a screenshot of the exploded diagram and part numbers. Oil is UTTO.
580k is pretty old. 80/90s? Case and NH merged in 99 according to google.
jddevel
Case and NH merged?? I`ve a local Case agent who sells new plant marked as Case. They have been able to supply previously needed parts. Anyway thanks for the oil guide and bearing needed possible.
