Buckets
I've got a old flat bottomed 18" jcb bucket with spring bushes. I thought all the old 3cs had spring bushes in their buckets
thought they were plain bushes/bosses with fixed (pinned/bolted) pins on the 3Cs with wear taken in the dipper end/tip link bushes
C
charlie2
not judging by the spring bushes in it ;)
the old 3c jcb buckets had spring bushes in them back in the 1960s and 70s manys the time ive changed the spring bushes from one bucket to the other while doing bucket change, there were a few guys that didnt even use the spring bushes the bucket would sway all over the place.
C
charlie2
I think 3cx buckets had spring bushes in them until late 90s.
last new 3cx i drove in 2014 had spring bushes in the jcb buckets if you had a quick hitch the bucket pins were stepped to do away with bushes in the bucket the ditching/grading bucket did not have spring bushes though just normal pins.
44 mm diameter pins. I think 3CX are 2”? Anyone confirm?
If you check the bucket pins on your 100C I’m pretty sure they will be imperial, 1 3/4”, although the pins and bushes will be listed in metric sizes, they will equate to the old 3cx imperial size. Every other pin on the machine will be metric 45mm 50mm 60mm etc
3cx buckets are to small even on most 8 tonners
Talking of buckets ..had this on a 027 last year . ..
Watling call them 44 mm. I have a new pin that I'll measure.
Yes 3cx, the biggest cockup they did! Give it proper excavator style buckets! Or it may as well be a 8 tonner!
Yes, that was my thinking, the buckets a bit small, for a 10tonner, and 3cx buckets are not the strongest especially when used with 7/8 tonners never mind 10t.
Disclaimer, I use 3cx buckets on both the duckling and 7.5t, I had quite a few from the 3cx + attachments, and didn't to be messing with different buckets for different machines.
