Brake fluid🤔
Gecko
Gecko
I can't imagine that machine makers went to the effort of having special seals in the master cylinder and then fitted a cap that says "use dot 4".
Pretty sure my 3CX says DOT4 on the reservoir where you must only use oil. (I'll check)
Canal Navvy
Canal Navvy
Matbro definitely had DOT 4 on the caps and I really can't see them having had the master cylinder fitted with different seals so I'm virtually certain that they were intended for automotive use.
Having a "special " made wouldn't have worked with their policy of chopping and changing suppliers depending on who had put them on stop 😉
my thoughts too ... or does it really have a clutch Mog??
Yes got a clutch😢 sadly, I could stick a fresh engine and auto box in but it has a nice water cooled 4 pot in there (that’s the cab heater sorted) but a shitty 3 speed box😢
it’s going to drive the same way as it came from the factory not like the other one👍
