Would you not close the dipper ram and rest the dipper on a prop, remove the hoses from the dipper ram, cap both ends of the ram, join the hoses, start the machine and using the boom lift the dipper off the prop! If the dipper drops then it’s a seal issue or a cylinder score!agreed with the ram fully extended Bri, but still disagree with it fully closed, holding the dipper up ... it will pass sufficient fluid to prove the seal fault, before any induced vacuum stops the motion
