better clarification dump truck or tractor with dump trailer, bizarre dilemma.
hi guys excuse me for the bizarre and bizarre question, I noticed that in the English and German market there are a lot of robust agricultural trailers pulled by 2-axle three-axle tractors usually central used precisely for earthmoving with large capacities even up to 10 tons, I I was wondering, wouldn't it be more convenient, quick and cheaper to use dump trucks? I think the trailer is a struggle to pull it through the fields and winding country roads what advantage would there be with the tipping trailer at the limit I think it is cheaper to rent a three-axle dumper truck am I wrong?
Steve
Tractor & dump trailer is easier to move around between smaller jobs so I would say it is just a convenience thing. As you say a dedicated dumper would shift far more tonnes for the same money.
maybe the tractor that pulls the trailer shouldn't get bogged down if it rains heavily, maybe the truck due to too much weight, even if it has 4 rear-wheel drive, it needs a mechanical shovel or other heavy machinery that pulls it without dragging it out of trouble, the tractor with trailer I see it more for agricultural use than for a construction site or a quarry, am I wrong?
sfincione forever.........
Steve
I think you are right tractor’s aren’t suitable for site or quarry work, they aren’t built as well as industrial equipment. Tractors aren’t even that good at agricultural work they are very much a jack of all trades & master of none.
a friend of mine fond of agricultural machinery suggests to me some agritruck agricultural equipment trucks, he tells me that they are the best on plowed fields they are more powerful than mine dumpers, someone uses them or owns one to be able to testify, thanks. sorry for the inconvenience.
the difference between the truck and the tractor is that the truck moves on its own means, under the cassane there are the driving axles, the frame is single monolithic, the tractor pulls the trailer that has idle wheels, therefore it is slower clumsy unstable , then they are two vehicles joined by the rudder and the hook, very dangerous and unstable as a road structure in my opinion, am I wrong?
thanks for everything what would be the best trailer currently on the market more robust and reliable, what can you tell me about AGROTRUCK trucks, I've never seen any thanks greetings.
