Best buckets and QH brand ?
The problem is they turn up from the factory worn out. I put a video on here a while back of a brand new 1.9t machine with a whites hitch and it already had a huge amount of play in it. I cannot see any advantage over a semi quick hitch at half the price
The problem is that they set their bucket pins to the same centres as the maximum extent of the hitch! SO no room for wear compensation.
But due to the safety pin they cant account for wear by adjusting th centres. They would need a different safety pin arrangement to allow wear to be taken up
Mine was a hydraulic setup. Two with the same issue.
I've only used the springy ones. Hence I don't understand the advantages over a semi quick hitch. Same amount 0f visits and spring are a pita to take breakers off of.
