Benford Terex 3Ton Dumper
Sledgehammer
Sledgehammer
Does anyone know the size of the clutch release shaft bushing fitted to the Newage 40M gearbox. The cost from the suppliers are outrages for a bush that should cost less than £5. Like all dumper spares we are being ripped off!
do you mean the spigot bearing in the end of the crank, for the first motion shaft or are there other bushes on the fork arm? not familiar with these
I’m going to guess number 57?
Ah right release arm fork spindle bearing (y) ... should be able to source some needle roller bearings easy enough if you have their dimensions
Try these guys. Have been really helpful recently sourcing new bits for a newage gearbox.
Sledgehammer
Sledgehammer
Thanks for the reply. No, not the crank bearing. There are two bushes shown
Thanks for the reply. No, It is the bushings on the cross shaft in the clutch bell housing on which the release bearing fork pivots.
Which one was it? If you get the size there are afew guys on eBay selling the bronze bushes for the right money!
Sledgehammer
Sledgehammer
Its the shaft the runs transversely across the bell housing. Thanks anyway but I had to bite the bullet with the outrages cost.
A
AndyM1958
Sorry a bit late I've attached a breakdown of a 40M Gearbox it looks like its part number CM2179 Bush.
  • 1582-1025 40M2B124.pdf
