The KX121-2 Had A green square button on the left hand console foe offset from memory
I havnt added a pic of the left as it does not have a button - happy to add a picture of nothing![]()
could be a 'concealed button' under the stick's 'skin' ...... looks like the right one might have beenAlthough we think it may be a separate button on the left console.. Watch this space
I've attached a wiring diagram... As for the button it is hidden under the plastic of the lever and can be difficult to push. If it isn't there then like I say someone has moved the switch. If you look on the diagram I've attached you'll be able to look for two wires that colour and find them somewhere under the left arm rest/console.I havnt added a pic of the left as it does not have a button - happy to add a picture of nothing![]()
Cheers buddy, already got that diagram -started with the WSM to check all was as original, which it is. Seriously there is no button either current or past on the left stick. Never was a soft spot,I've attached a wiring diagram... As for the button it is hidden under the plastic of the lever and can be difficult to push. If it isn't there then like I say someone has moved the switch. If you look on the diagram I've attached you'll be able to look for two wires that colour and find them somewhere under the left arm rest/console.
Take loads of pic of your cab so we can see the whole thingCheers buddy, already got that diagram -started with the WSM to check all was as original, which it is. Seriously there is no button either current or past on the left stick. Never was a soft spot,
