Auger recommendation for use on TB016 and possibly Avant 860
We run Digga on the hire side, have one in for a bearing refit at the moment, but it’s 15 years old, and at best very abused!
Mick I didn't realise until I tried it today that the tb016 only drives the auger 1 way, is it possible to reverse it too dobyou know?
Is there a bolt under one side of the pedal which you need to adjust so the pedal goes both ways (there is on 219) or does it have a tap to switch between 2 way circuit and free return?
I noticed today there is a bolt on lhs when sat on the seat. I'll check on Monday
Is the pump straining when you press the other side of the pedal? If so it may need the valve opening where the quick couplers are fitted
No the bolt stops you pressing the pedal to the left
