Auction watch
Bargain I would say. I have a set similar these on the Moffett and bloody brilliant. Good for unloading a whole lorry from one side :) Think mine are 1200 with 1000mm extension, but never measured.
wonder what capacity they are ? on 16" carriage so 1 to 2 tonnes at a guess ... can't see 'em coping with 3t ... very cheap though ... would fit my VA-r/blade carriage ... but I'd probably break 'em :rolleyes:
Mine have quite a lot of 'flex' with a ton on them and fully extended. I try to be gentle with them.
can well imagine ... there can't be a lot of 'bearing' left when fully extended ...... if I can't reach it with the 'Drema's forks, another 900 mm ain't gonna make a lot of difference ... time to put the extensions on :giggle::LOL::ROFLMAO:
and that's with the boom closed down :rolleyes::giggle:-- could unload from/over 4 trucks away with her, on a stretch :giggle::giggle:
would have a job hanging it on the back end of a trailer though, like a moffat :ROFLMAO:
That is cheap but carriage be more than that prob...and I bet not lolerd
would go on a std 16" carriage and not difficult to get tested ..... just need an additional spool for them, which most FLTs usually have, unless used for side shift already :rolleyes:
Little project for someone!
I`ve got the same, bought it new around 30years ago.
It`s worked fine off a good 13a supply. At the time the sales spiel was saying the windings where heavy enough so it didn't need a cooling fan too still get a decent duty cycle.
The only problem I`ve had was the control board packed up, Tech Arc https://technicalarc.co.uk/ in york repaired it and worked fine since.
Feed roller spares are getting had to find now.
