Urea which yeah is from piss but contrary to popular opinion not extracted but a man made version. I love telling farmers what it is thoughPigs piss![]()
Yeah most will immediately envisage another income stream till they think it through.Urea which yeah is from piss but contrary to popular opinion not extracted but a man made version. I love telling farmers what it is though![]()
Best kept below 30 C for long term storage, and it’ll not be likely to freeze in many parts of the UK. We’ve found that it starts to freeze at about -12, at -15 or thereabouts it’ll be solid (The makers say it freezes at -11). If you keep the same container for transferring it you’ll not have too many problems. If you get crystallisation, slosh the Adblue about and it’ll dissolve. If you need to wash crystals off anything, distilled water does it every time. You absolutely can’t put Adblue in a container that’s had anything else, including tap water, in it unless you’re looking for issues.It’s certainly temperature sensitive for a start, I don’t think it expires as such but if the air gets to it, it will crystallise in the empty void of the container. Not so much of an issue with an ibc as you draw from the bottom but worth knowing if you transfer it from one to an empty can and then into the machine. I’m pretty sure it’s the transfer from clean to whatever else, that causes a lot of the issues with adblue for people. It needs to be kept so clean and hence why a lot of firms just run smaller cans of it now rather than ibc’s etc
I'm reusing 10l AdBlue containers.what container are you using when you buy the Adblue?
Just going by the dash / ODB11 errorHow do you know you’ve got crystals in the tank?
