33 - c/ d hanomag strengths defects performance comments experiences.
hello, as you know I have a soft spot for the German women especially for the 55d hanomag the 44 and the 66 and the 77 which for me is a mammoth monster, but on the 33 and the 22 what can you tell me? the 22c was owned by a villager of mine who used an earth embankment to build an embankment, the trucks arrived on his land they unloaded the soil and he spread it and leveled it evenly, but it was a 22c a little worn and cloaked, it had no thrust and power, he did the job because the ground was soft and soft, a wreck boar a wreck. on the net I found some specimens of 33 hanomag c and dwhat could you tell me about this machine such as power performance strengths defects thrust penetration, can you find spare parts in case of repairs? thanks let me know.
:unsure:
no lack of push in that :cool:
here's a different one for you @barracane
Muir Hill A5000 wheeled backhoe Loader.
9000 Genuine Hours with hour clock working.
6 cylinder Perkins engine instant starter and runs well.
Forward / reverse manual shuttle.
Hydrostatic drive , strong torque converter.
2 wheel steer / 4 wheel steer & crab steer all working.
2 wd / 4 wd selectable working.
Strong hydraulics.
Piped for 3rd Service front & rear.
C/W front bucket & 1x rear bucket.
Air tank fitted and working.
Very strong machine , starts on the key and all works.
No leaking rams.
Delivery available throughout the U.k.
No vat. £5750
View attachment 27527View attachment 27528
Strong hydraulics.
No leaking rams.
No vat. £5750
Now that's an oddball!👌
basically this backhoe would be like a rudimentary telehandler with the cockpit on the left, it was a military vehicle, how much would it cost? which engine would it have? what about maintenance ??? it has a rigid frame with an old-fashioned steering axle, who knows the transmission and the axles as they are put. it will have the right thrust and penetration to do its job, it will be fast enough and powerful enough to maneuver. to posterity the arduous sentence, thanks for the report I did not know this military machinery on leave, thanks.
I`ve got a muck fork for a Muir Hill A5000 in the yard here
Strong hydraulics.
No leaking rams.
No vat. £5750
I don't even have a mechanical shovel, returning to the initial topic I think the weight is about 10 tons, the 1.5 cubic meter bucket the engine is not hanomag but I think perkins I would not say a fool, your military backhoe than engine and transmission adopts, just to know thanks.
I would say almost certainly military origins (y) ....... 6 cylinder Perkins .. probably 6354 at a guess :rolleyes:;) ... you were right with your guess :):cool:
one off google for you
Left hooker
Left hooker
A recycling yard had a couple hanomags few years back they now run a small newholland loading shovel
While I was looking for the above pic found the pic of same lorry at a quarry where the yard shovel had broken down and they sent the pit one up the lorry carries just under 12 ton basically there was another lorry load on the floor behind 🤣
"twist of fate, if you do not take care of the maintenance. your military backhoe does not look bad, it does not skid I think it still has good penetration, the telehandler type central arm does not convince me very much, it seems that it has play that pitches the lifting phase a little , the excavator behind the backhoe looks a little badly reduced, however not bad, it has the rigid frame but it still seems to have the right power and the right penetration. photos you have seen.
