3.5t tipper truck for towing
Looks like good value at 3.5k
Is that zero tail swing with your ammo box :)
Oh, and that
no but it holds everything you need to take roll bar off, direct mount a bucket, grease gun, chain, and of course, a 10mm spanner for the two bolts that hold it on if you need zero tail swing 😉
Cambelt, oils and pads will see you well!! Watch out for rust on the inner cab sills.
Had it out again today, three packs of 600x600 slabs in the back and the ifor with the micro behind it. No drama.
The 2.3 are belt and chain for top end. Some swap them some dont. I never have.
You think yours is big, ive got an 11ft 2in tipper on order with a 2ft tool box. But with a 4100 wb chassis to keep the back axle in right position...most only have a 3750 wb and that just doesnt work right but they just see cost of the longer wb.
Yes, i can believe it, i also believe you can get just shy of 5t on and they still tipit off.
That's impressive
Farm I used to work on had a composting site and several of the regulars had to have a helping hand witb there weekly tip off from the telehandler as the tippers couldn't manage it
A old LDV can tip 5 ton, the handbrake wouldn't hold it on the bit of a ramp, but would tip :D
How do I know it was 5t? I loaded 20ton of tarmac on it in 4 loads. One of the an old boss`s 8 wheelers came back with a load, and the boss had a road up to a farm shed, but couldn't get the wagon there.
I can get 1.6 on my 14ft dropsider and was 1.3 on my ali beavertail.
So a tipper should legally carry about 1.2?
If that's the case, if not too bad.
My sprinter tipper carries around 1.4 but its old and pre all the modern shite. My tranny crew cab was around 900kgs.
That's impressive
Yes, right body with right ram makes a very big diff
Reversing then slamming on hard whilst holding the tipper switch can help to get things moving when ‘loaded’! (and can also get the front wheels airborne....)
Anything modern has a right tantrum if you try to do anything with the handbreak off
And they are good load capacitys
I took an 11 plate transit in for tarmac the other day big old lock box up the front but empty left me with 800kgs capacity
New shape Double cab with tools in is about 700kg left
Danny
Danny
Be intrested to see what it weights in at with the ali butt
Mines 2490kg i think with a steel butt
