2005 thwaites pt6000 starting problem
Rye76
Sometimes starts ok but lately it wont start. Turn key and it tries to start but falters and a rapid clicking before it cuts out completely. Battery is fully charged no issue there I cleaned the battery terminals and the connectors last week when it did this and it started up no problem. Came to start it up today after a week of not running and same again it tries to turn over then rapid clicking noise then completely dies. Help gratefully taken. Also oil lights come on on the dash.
Steve
Sounds like lack of amps at the starter . Check battery condition & all leads / terminals to the starter including isolator switch and earth as Canal Navvy says.
jd6820
jd6820
Check the earth to the chassis, then power supply to fuses and through the resettable fuses on the dash.
Where the two or three + battery cables bolt to the battery terminal clamp they aren’t making a good connection with each other and the terminal, try the earth cables for the same, if it has an immobiliser, make sure the battery isolator is turned on before starting, depending how the immobiliser, if fitted! And how it’s been wired, if the immobiliser earth is direct to a battery earth on the battery side of the isolator then if the isolator key is off the starter will use the earth through the immobiliser to start hence the flat battery syndrome!
sounds very much as everyone says ... dirty/corroded/burnt connection somewhere ... don't forget the link from the solenoid to the actual starter too ... easily overlooked and takes some current
Rye76
I checked those last week and cleaned them up tightened back on and it fired up straight away but this week it's back to square one rapid clicking!
can you determine/isolate where the clicking is coming from???
jd6820
jd6820
As Mick says those Terex's usually have an isolator switch somewhere in the engine bay. See if this has been bypassed (both leads on the same terminal). If not try bypassing it and try starting it again.
