13t hitch width
Thomas7740
Thomas7740
Does anyone happen to know the difference between standard 13t hitch width and cat 13t width? I know the cat is narrower but not sure if it’s something the grinder will solve 😅
I could go measure but it’s Sunday night, I’ve got beer and the fire lit, I’m not driving miles to measure 😂
Thomas7740
Thomas7740
Case 255mm dipper width, Cat 220mm.😎
Thank you, it’s for my JZ140 to pick up the buckets that’s on the cat and case (they both have cat hitches), probably get away with grinding a half inch off each side the hitch? 🫣
Jcb will be 255mm as well, depending what hitch you have on the machine you might be ok
