Nibbler, has anyone...
Ever repaired one?
It's beaten me ATM. Cheapo bergen just stopped on a roof sheet job, finally decided to sort it as I need it ...
Got it spinning again by hand but assemble it again and no joy.
Anyone an expert ? Not really ripped air stuff apart before.
Or am I wasting my time 😒
Ever repaired one?
is there a timed port plate/valve disc in it? ... back together right? :unsure:
Update ..or not 😀
I gave up and slung it.
Any recommendations for anything decent for cutting box section sheets?
before I go out and get more red stuff?🫣
M12 Nibbler is staring me out 😬
Update ..or not 😀
5" thin disc and guide edge ;) -- hot knife through butter (y)
nibblers're hateful thing to use on profiles
for straight sheets cuts
we gave up on nibblers years ago now use the metal cutting blades on rail saw namely I bought a cheap evolution (was a few years ago, was only rail saw that cut metal then) but the other brands have their own metal cutting circular saws and the red one is pretty good
sweep off the swarf or it rusts the plasticote
grinder disk tends to melt the plasticote and you get peel back though
depends on how hard you go at it though .. also cut an end that's gonna be under the flashing
have seen
have seen a few of the yanks on youtube cutting profile wit a TCT blade in a circular but with the blade reversed--doesn't rip the sheets and seems to work well
Hence my question as not going to be covered.
. Was also slightly worried about the surrounding area combustion swiftly...not so much this week lol.
the metal cutting blades don't spark but can throw stuff at your face although the newer designs like Milwaukee and dewalt are better
K
kato512
Update ..or not 😀
I have the Milwaukee metal shear and nibbler. The shear doesn't get used as much as the nibbler. Corded nibbler hasn't been used since the cordless has been purchased.
We have got the makita corded nibblers, big and small. Both useful but also limited as to what they can do. I see Melliff do a yellow 18v copy so may try that .
Also trying to find a metal cutting blade for my 54v dewalt circ if anyone has any suggestions.
got a corded Fein nibbler and a Mak hand shear .. both 'horses for courses' .. neither are my choice for profile -- good tools in the right applications
