F
fred
Either will work. Work out your fall say it’s 250mm move the receiver down 250 at your end location making sure to keep the staff in same place then use remote to lower the beam until you hit tone. Job done
We use lecia 860 rugby. And that's pretty much exactly what we do. Even has the remote so is a one man operation. Just need to make sure you have the X and Y axis pointing the right way on the base.Either will work. Work out your fall say it’s 250mm move the receiver down 250 at your end location making sure to keep the staff in same place then use remote to lower the beam until you hit tone. Job done
