sandbags89
Hi all,
new member just joined in search of a few clued up people of the plant world...
I have a mini excavator (yanmar b08-3) which will not start up and i can't for the life of me figure out why. It turns over, smokes out the exhaust but just won't start up, even when it seems like its just about to.
First happened months ago, was being used no problem, turned it off to have a break, then it wouldn't turn back on. Same thing, would turn over but wouldn't start. Was confused, checked for any obvious reasons, but eventually just topped it up with diesel in case (even though it had plenty of fuel in there) anyway it then started up so didn't think much of it. Parked it up, few weeks later got it out and used it as normal again. Noticed it performing a little sluggish, when pushing or using the arm to lift a more heavy/stubborn load it would sound like it was about to stall, so id quickly stop before that happened. Eventually I made the mistake of not stopping in time and it stalled in the middle of the garden and wouldn't start up. Tried topping with diesel again but no luck this time. Spent ages trying to start it but no luck. So left if for an hour and tried again and luckily got it to start, so quickly parked it up....and it hasn't moved since. Haven't been able to get it going for few months.
From my own limited knowledge and through bit of research online, I assumed it had to be either no fuel, engine not breathing properly, air in fuel, or water in fuel. I have done the following:
Sorry for the long-winded post, but just trying to paint the full picture.
Would appreciate any advice to get this working again!
thanks in advance
I have a vid of the start up but can't figure out how to upload it. Doesn't allow me to provide the link
- The smoke from the exhaust leads me to believe it has fuel, but i checked anyway and fuel seems to be making its way through the rights hoses and getting to the injectors ok.
- Checked all hoses, no blockages
- checked injectors for blockages or gunk build up (these were also replaced not too long ago)
- changed fuel filter and cleaned out bowl
- changed pre-fuel filter
- emptied fuel tank and topped with fresh diesel
- new air filter
- changed oil and filter while i was at it
- new glow plugs
- bled air from fuel (although may be helpful to know correct procedure for this. I done so by cracking a nut that looking like it was for bleeding purposes. also tried cracking the nuts on the metal fuel lines connected to the injectors)
- charged battery (and tried starting with a booster pack)
thanks in advance
