T
Tacitus
Short answer yes, if it is not a modern smart charger that can recognise the charge of the battery and vary the supply accordingly.Can you damage a battery leaving the trickle charger on too long?
Lead acid batteries, degrade mainly due to 3 factors.
Corrosion of the plates from the acid,
gassing of the plates at the end of the charging cycle that dislodges lead particles that fall to the bottom of the battery
and sulfation that happens when the battery stays with low charge, sulfur crystals form on the plates reducing the active surface. If stays discharged for long time, the crystals get hard and they are no longer reversible.
Temperature accelerates all of the above.
A smart charger detects the level of charge and floats the charge in a way that there is no gassing and no sulfation
