this looks to be a recipe for disaster
Pointless contraption of the year...there's a reason traditional stackers have base runners. Try loading racking with that.🤦‍♂️🤣
Stacking empty pallets on a shelf is the only thing I can see it being useful for.
When I see something 'just a bid dodgy' on fleabay, I look at the seller
146 transactions and only two people liked him - that's not encouraging.
T
Tacitus
I don't think it would work at all. Say a pallet of concrete blocks in front of you. The center of gravity is under the pallet some 50 cm in front of the lift.Start pumping to lift the pallet off the ground and the first thing to happen is the back wheel go up in the air and the pallet stays put. Where is the counterbalance?
Those boxes behind the front wheels, should be lead and all the way back I agree, good for empty pallets and not more than 3 at the time :unsure:
looking at the ad. again it says 200kgs .... presumably that's its capacity on a billiard table smooth, level, floor :rolleyes:
Guessing the 10 st counterweight would lift less than the 14 st counterweight, what’s the WLL???
