Wanted- hydrostatic compact tractor 25-30HP
And incidentally does anyone on here have a login to maskinisten?
Ive asked Frank but no answer atm.
I knew it's to new for you.
It might be avant or aftermarket but I'm sure someone on arbtalk had something fitted to one of the mini loaders to give cat 0 three point and a hydraulic pto just trying to find it
I think avant do. I'd be surprised if multione don't
How's that for a looker.
Not got biggest capacity but will do us fine for shifting logs and kids to cut their teeth on.
Few bits to sort but handy money can't complain.
And...it's actually a Valpadana badged as McCormick 😂
frame steer, Alpine type thing??? :unsure:
Frank's on here LL, .. PM him .....but I'm a member on Maskinisten ... why don't you just sign up
You got a contact with Swan vestas?
That little saw/splitter cost £2k, and it's an easy bolt on sale to posh customers round here after a tree clearance job. Plus it'll make it really easy to process arb waste wood for my stoves and a few bags for customers in the village too.
I'm quite impressed with it, it'll slice up to 10", and the screw splitter is really nice to use and will do maybe 16". With two men it's pretty quick, and there's very little bending down. It's really good for all the small diameter stuff that is a nghtmare with a chainsaw. Larger stuff you have to ring up before putting onto the splitter, but 10" diameter lengths are as much as I want to handball anyhow! I can fit the Sherpa on the trailer alongside to lift the larger lengths to chainsaw up.
I won't tell you how much money I'll get per day for it because it's probably more than you'll get for an 8 tonner... :ROFLMAO:
When the jobs are worked the way round i want them to be you'd be surprised what my 8ton can make per hour. To be fair you'll probably have plenty logs the right size for a dinky setup like that, be no good for what i get.
Hg2702
Hg2702
