Anyone use a compaction wheel on a mini?
If so are they any good
but couldn't come up in layers then ..... put a two way/4 pin head on it .... or even a swivel headOften thought about one but would want the headstock welded at 90degrees to the machine if that makes sense. So you could track along side a trench and compact it rather that straddling which you can’t always do. Then I think if that’s the case just track along the trench![]()
No that is the downside normally a plate job to start with also have to consider the limited reach on a mini digger would allow for such a scope of works like on a larger machine. 9 times out of ten your tracking over what your working on unless your working your way out of somewhere. Same reason a plate doesn’t really work on a small machinebut couldn't come up in layers then ..... put a two way/4 pin head on it .... or even a swivel head
I had thought about making one for my mini but after reading this perhaps I should stick with the WackerI've got a homemade one that uses the track idler wheel off a 20 tonner. It'll fit down a trench dug by a ten inch bucket and works well for me.
I certainly would not put a less experienced operator on a mini with a compaction wheel as it would be awfully easy to roll the machine.![]()
