Hydraulic oil top up
T
Tilleyrose
Hi just got a j c b 8014 year 2003 hydraulic legal is low can someone please advise me on how to top it up many thanks
diggerjones
diggerjones
There will be a sight glass somewhere and probably above it will be some kind of filler
Fully close the bucket ram, fully extend the dipper, fully offset to the right and drop it all on the floor ...... now what does your sight glass look like ... if it ain't full, top it up ... in that position you will have as much oil back in the tank as you'll ever get, unless you're digging a deep hole, off set right, ... to fully close the boom ram.
Oh and welcome to the forum ;) ....
that above is a 2002, previously an 'early pride and joy' of Ollie @Gunners ....
now in retirement at Chez Druid ...
sort of, 'cept when I have need of Lil' Jake's help ;) ...
and ain't worth starting the 'Drema for
I think if you put the arm and boom and bucket in the position in the first picture and drop it to the ground all the rams will be less full and you can fill to the fill point in the glass.
there's still a fair bit in the offset ram though Mick .... cranking it to the right, as well, puts the max. poss. back in the tank (y)
Yes there will be but as long as there is room for expansion in the tank, it’s a compensator for all rams in and all rams out, the tank is the differential😊
yeh, but I like to err on the side of caution .... 's not a very big tank on there Mick ;):giggle:
The gauge is normally 2/3 the way up the tank, so even when it shows empty it’s half full, and when it shows full it’s not!
